wdanker
Dec 26, 2016Initiate
No Internet connectivity
I am on Verizon FIOS, the coaxial goes in to their wireless router, which then hardwires into the FS116 switcher.
When I connect my comptur directly to the the ethernet cable coming from their wireless router, I get a solid connection. When I plug that back into the switcher (FS116) none of the machines connected light, including my TV, Computer, and Netgear Night Hawk.
I have unplugged everything and reconnected, situation persisists.
- TrikeinLuminary
When you connect direct into the FIOS gateway, what IP address do you get? Don't need to know the exact IP, just wether it is a public (68.1.2.3) or private (192.x.x.x, 10.x.x.x, etc). My guess is the gateway is in bridge mode, so it will only give out 1 public IP, while the switch has 16 ports.
PS. The switch also is only rated for 10/100Mbps. If you pay FIOS for a package above 100Mbps, I would suggest upgrading the switch.
- wdankerInitiate
Thanks for the reply. I get a 192.x.x.x address. I also plugged my comptuer directly into the switch to take all the other cable out of play and I cannot see the internet. At this point, I am pretty sure my switcher is fried. Thanks for the reminder on speed. I am getting ready to buy a replacement, leaning to the FS over the GS, I'm on their 50 plan and seem to be able to stream anything I need at this point.
