fladave
May 09, 2017Aspirant
No longer supported on my AC 1900, is it secure?
I'm using a C6300BD on Cox cable and I can no longer log in to change the channel or router settings. I see a device that I can't identify on the wifi network. It's showing as a Unix readyshare. I'm ...
fladave
May 11, 2017Aspirant
Thanks for your responce and help. I will try what you told me and let you know the result.
fladave
Hi,
I did what you said but with the same results as before. The message appears in red above the log-in area: NETGEAR router is not found or is not supported. Also make sure the device is not connected to the guest network of the router, and no IPv6 is enabled.
- fladaveMay 11, 2017Aspirant
Hi again Darren,
I was able to log in after noticing that the IP address that my modem was using was not the actual IP address of the unit. I clicked it at different times and found two different addresses in the bar that were not the actual IP address. Once I manually entered the correct IP address I got in but I still couldn't shake the user that I can't identify. I tried changing channels but the device continued to follow. I attempted to change bands but wasn't able to get switched over as the unit wouldn't let me use the password that I believe is correct. Could this other user somehow have my info or block me from doing whatever to keep him away?
