fladave
May 09, 2017Aspirant
No longer supported on my AC 1900, is it secure?
I'm using a C6300BD on Cox cable and I can no longer log in to change the channel or router settings. I see a device that I can't identify on the wifi network. It's showing as a Unix readyshare. I'm ...
DarrenM
May 15, 2017Sr. NETGEAR Moderator
Hello Fladave
You may have to contact support did you purchase this modem from a store or your internet provider. If you got it from your provider you may want to contact them if not contact netgear support.
http://www.netgear.com/support/contact.aspx
DarrenM
