Skrobbins
Mar 22, 2018Aspirant
No phone port on modem router
At the risk of asking a stupid question, how do I hook up my landline phone to my xfinity cable through my new modem router? There aren't any phone ports on the thing.
vkdelta
Mar 23, 2018NETGEAR Employee Retired
you need to buy C7100V for Phone support. It is voice enabled Modem Router.
C6250 does NOT support XFINITY LAND LINE Phone.
- SkrobbinsMar 24, 2018AspirantThanks for suggestion. Are there any less expensive options with Netgesr equipment? My Internet speeds are only 150 so I don’t need anything terribly powerful - just reliable and able to reach across my 100 foot house from the corner. Thanks
- vkdeltaMar 25, 2018NETGEAR Employee Retired
there is CM500V but it is Modem+Voice only. Not router/WIFI. you will need a CM500V + seperate router.
