Darienmen100's avatar
Darienmen100
Follower
Jul 09, 2016
Not able to connect to 5GHZ connection C6300
Earlier today the connection to my 5GHZ disappeared. I have turned it off and back on and it is now showing as a avalibale network. But when I try and connect it just says cannot connect. Any steps that I can try?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Darienmen100
    Have you told you device that you are trying to connect with to forget the network then try to connect to it again.
    DarrrenM
