vaibhavrm's avatar
vaibhavrm
Initiate
Jun 12, 2021
Not getting 600 MBPS speed through wifi for C7000v2
Hi I have a xfinity connection with 600 MBPS speed, when I am using my wifi max speed I get is around 250 MBPS however when I connect any laptop via LAN I get proper 600 mbps. I am novice when it comes to router setup. can someone please guide me what config changes I need to make to get wifi to full speed.
    • vaibhavrm's avatar
      vaibhavrm
      Initiate
      Understood, any model recommendation which will give me 600 mbps?
      • plemans's avatar
        Sadly it isn't just a "what router will give me those speeds" but what device are you using.
        A lot of times the bottleneck isn't necessarily the router but the device you're using and the environment you're in.
        I'd recommend looking at the article I linked to for info on what to expect. then I'd recommend looking at smallnetbuilder for some actual tested reviews of routers.
