dolpha
Sep 08, 2022Aspirant
Old router and download speed
Hi, I have a C3700 router purchased in 2014. Although it's working fine, downloading speed reaches only around 90 Mbps while my internet service provider supports up to 300 Mbps with my plan and my ...
Sep 08, 2022Guru - Experienced User
Xfinity has been requiring higher specs for lower and lower speed tiers. You'd actually have to contact them to see what speed tier they support with the C3700. If its faster speeds, then you might want to check your port speeds on the router.
If thats all they support, it might be time to look at upgrading to a docsis 3.1 device so you can use the speeds you're paying for.
