asthelen
Mar 14, 2016Follower
Only one device has internet access -- minimal options in genie
I have a C3700-100NAS and ever since I got it, I have only been able to connect to the internet on one device at a time. Whichever is connected first gets internet access, but each computer/phone aft...
vkdelta
Mar 24, 2016NETGEAR Employee Retired
which ISP are you on? I can take a good guess who it will be.
your modem has been set to "BRIDGE MODE" forcefully by the ISP.
if you set to factory default and disconnect the coax cable, everything will be ok. but as soon you connect to the coax cable, your ISP is pushing a configuration to force the device to "BRIDGE mode"
