Reid2
Feb 23, 2017Aspirant
Orange light on CMD31T modem
 This refurbished unit worked fine for a few minutes last week when I put it online with a new N600 router.  But then the connection stopped and I presumed Comcast did that automatically.   But today ...
- Feb 28, 2017Thank you both above for helping. This is a great forum. On reflection: I thought the refurbished modem, which cost only $18.39 delivered by Amazon, was saving money. Now, whether it is defective or not, it appears money will better spent to just go buy a new modem, a Netgear CM400. I'll keep the CMD31T, which may be OK after all, for some day when I can access the diagnostics on a PC via ethernet cable as instructed. OTHOH, I will be back for help (you just know it), if trouble crops up in initializing the CM400, too. :smileyvery-happy Cheers to all
Reid2
Feb 28, 2017Aspirant
Cheers to all
Reid2
Mar 05, 2017Aspirant
The CM400 just installed a few hours ago worked fine out of the box. What a pleasure! Presuming now that the CMD31T, which I bought as a refurb, was probably defective for its first owner too. And I learned a lesson: that cheap (CMD31T refurb. @ $18.39) can be really expensive.
Thanks again for your helps!
