Lpap's avatar
Lpap
Follower
Jun 04, 2017
Orange light won't go off
I have had this modem for a bit and it has worked perfectly fine. I just moved and now when I plug it in the orange/amber light won't change to white indicating that the internet connection isn't ready. It's been plugged in for over an hour and I never had this problem in my old house. Any ideas on how to help?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Lpap
    I would contact your ISP make sure they have the modem set up correctly for your new address it could be stuck in the system back in your old address.
    DarrenM
