johnrp0510
Dec 01, 2016Follower
Orbi and C6300
Currently using a Netgear C6300 modem/router. Interested in using the Orbi. Will it work with the C6300? Does the Orbi broadcast different SSID's for the 2.4Ghz and 5Ghz wifi networks? Any suggesitons greatly appreciated.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello johnrp0510
Yes it will work with the C6300 you can set the modem to modem only or use the orbi as a AP. And the orbi only broadcasts 1 SSID and bandsteering will put your device on the 5ghz and 2.4ghz on its own.
DarrenM
