imssh
Apr 13, 2022Guide
Orbi Satellite suddenly not connecting
I have a CBR750 with an RBS750. They have been working well for months. Today, they stopped working together. I updated the satellite to firmware V4.6.7.13 thinking that might help with a strange...
- Apr 13, 2022
What FW is loaded on the CBR?
What FW version was prior loaded on the RBS.
Only approved released version for the RBS that comes with the CBR750 is 4.6.5.14 currently. The v.13 version if for RBSs that are packaged with the RBR series.
Apr 14, 2022Guru - Experienced User
Ok just wondering.
Ya historically NG auto update services have not been good for users so I believe over time NG is holding that back until a later time frame.
Keep with checking the NG download site and here in the forums as I try to keep what's officially posted on NG sites included here.
Be sure to keep the CBK752 separate from the RBK752 kits in regards to the RBS.
imssh
Apr 14, 2022Guide
All good advice... thank you!
