Retired_Member
Dec 26, 2018Parental Controls not working on Netgear C3700
Good day. I just happen to be checking on my router and discovered my parental controls are no longer working. I am hoping there is a hotfix versus me going out and purchasing another router. Than...
Retired_Member
Dec 29, 2018Good day and thank you for responding to my post. I have reset the router. Verified I have the latest firmware on the router. Uninstalled and reinstalled the Netgear Genie app. I read in a thread that parental controls do not work with Wireless AP on. I followed the steps in the thread but was unable to disable the Wireless AP per instructions given. Could be due to the fact it was an old thread. I deleted my OpenDNS account and recreated via Netgear Genie. I then went into OpenDNS and added my home network to the account and verified IP addresses. I changed parental control settings in Netgear Genie from moderate to high and waited 5 minutes. I could still access porn sites. I went to OpenDNS and made parental control setting changes. I waited 5 minutes and also pushed changes via the OpenDNS agent. Status unchanged. I can still access porn sites. These are the steps I have taken thus far. Thank you.
antinode
Dec 29, 2018Guru
> [...] I read in a thread that parental controls do not work with
> Wireless AP on. [...]
_Which_ "a thread"? Parental Controls may not work on a router which
has been configured as a wireless access point (only), but that's not an
option on a C3700.
> [...] I followed the steps in the thread but was unable to disable the
> Wireless AP per instructions given. [...]
That non-description conveys no useful information.
> [...] Could be due to the fact it was an old thread. [...]
Could be that it didn't apply to a cable-TV modem+router like yours.
But, with my weak psychic powers, I have no idea what this "a thread"
actually said, or what you actually did.
- Retired_MemberDec 30, 2018
For your info, a thread is an email exchange like this one. There is no need to share what the thread said because one, it did not work and two, it was an old thread (post) as I mentioned. Thank you
- antinodeDec 30, 2018Guru
Thanks for the explanation, but I already knew that. My question
was '_Which_ "a thread"?', not 'What does "a thread" mean?'
> [...] There is no need to share what the thread said because one, it
> did not work and two, it was an old thread (post) as I mentioned. [...]
If you had decided that it was all that irrelevant, then why mention
it?
> [...] I followed the steps in the thread [...]
Do you believe that there's "no need to share" what you did?
> [...] I have no idea what this "a thread" actually said, or what you
> actually did.
Still true.- Retired_MemberDec 30, 2018
Thank you. I have decided to go with a different router. This is the 3rd netgear device that has gone down on me. Take care.
