Retired_Member
Dec 26, 2018Parental Controls not working on Netgear C3700
Good day. I just happen to be checking on my router and discovered my parental controls are no longer working. I am hoping there is a hotfix versus me going out and purchasing another router. Than...
antinode
Dec 30, 2018Guru
> For your info, a thread is an email exchange like this one.
Thanks for the explanation, but I already knew that. My question
was '_Which_ "a thread"?', not 'What does "a thread" mean?'
> [...] There is no need to share what the thread said because one, it
> did not work and two, it was an old thread (post) as I mentioned. [...]
If you had decided that it was all that irrelevant, then why mention
it?
> [...] I followed the steps in the thread [...]
Do you believe that there's "no need to share" what you did?
> [...] I have no idea what this "a thread" actually said, or what you
> actually did.
Still true.
Retired_Member
Dec 30, 2018Thank you. I have decided to go with a different router. This is the 3rd netgear device that has gone down on me. Take care.
