Chas1938's avatar
Chas1938
Follower
Jul 19, 2022
Password , c7000
somehow the device password migrated to my network and replaced my user password resulting in all our device getting "incorrect password" messages. in checking this out online I tripped on a net gear change password site. I changed my network back as originally set up. It seemed to take but it did not change anything to wit my network password is the device password. all works now with the password change but it doesn't seem right. Have do I get to the official net gear site to change passwords?
1 Reply
  • plemans's avatar
    did you log into it using its ip address?
    Try 192.168.1.1 or 192.168.100.1
    If the admin login info has changed, you might need to factory reset to start back at stock.
