sunywoman's avatar
sunywoman
Follower
Jan 05, 2017
Password reset
Set Password
Old Password
Set Password
Repeat New Password
Enable Password Recovery
Security Question #1*:Select a questionWhat was the name of the first NETGEAR product you purchased?What was the name of the first school you attended?
Answer*:
Security Question #2*:Select a question
Answer*:
*=required information ok so this is the page i am referring to and it won't take any old password i put in and this is after I did a factory reset (model# not shown in drop down=WNR 1000v4) the reason i did a factory reset was because no matter what answers i put in on the orignal questions it would not accept it and i know the answers were correct. what do i do on this page to reset my password??
Last time password was recovered
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello sunywoman
    When doing the factory reset make sure you hold the reset button for at least 10 seconds to make sure it wipes all the old settings.
    DarrenM
    • altzar's avatar
      altzar
      Why do I need to do a factory reset in order to change the password? What password should I use after the reset?
      • altzar's avatar
        altzar
        By the way, I am running Mac OS Sierra 10.12.3. FYI.
