TxAnn's avatar
TxAnn
Password won't work
In trying to sign into the Genie or access my wifi cable modem, the standard log in won't take the password.
It says, FAILED, Check password.
admin
password
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Txann
    If you got to 192.168.0.1 in your web browser does the login of admin/password work?
    DarrenM
    • TxAnn's avatar
      TxAnn
      No, that won't work. It says password failed.
      • DarrenM's avatar
        DarrenM
        Hello TxAnn
        Then it seems that the default password was changed at sometime and the only way to fix that is to factory reset the modem but this will lose all your settings and you will have to set up the modem again.
        DarrenM
