TxAnn
Sep 06, 2016Aspirant
Password won't work
In trying to sign into the Genie or access my wifi cable modem, the standard log in won't take the password.
It says, FAILED, Check password.
admin
password
- DarrenMSr. NETGEAR Moderator
Hello Txann
If you got to 192.168.0.1 in your web browser does the login of admin/password work?
DarrenM
- TxAnnAspirant
No, that won't work. It says password failed.
Hello TxAnn
Then it seems that the default password was changed at sometime and the only way to fix that is to factory reset the modem but this will lose all your settings and you will have to set up the modem again.
DarrenM
