Dave_61
Nov 12, 2020Aspirant
PC slow to make connection through gateway after network address change
Model C6220 Firmware V1.02.11 Windows 10 home 19041.630 Chrome browser I wanted to add access points to my WiFi network. I reset my router to factory defaults as I was using an non-standard ad...
Nov 12, 2020Guru - Experienced User
What non standard address were you using on the LAN side?
How is the LAN side IP addressing configured now?
Did you power OFF ALL devices then back ON after resetting the modem and setting it up again?
What additional APs did you add?
- gburns53Nov 12, 2020Aspirant
nm
- Dave_61Nov 18, 2020Aspirant
Original LAN network was 10.XXX.XXX.0, subnet 255.255.255.0. I switched the router to more standard 192.168.0.254 in order to configure access points (reused old router hardware, just not as a router).
AP's are not connected now because of the issues I was having, but they were an old Cisco WiFI Router and an old Netgear WiFi router. Again, they were not being used as routers, simply as WiFi AP. DHCP was turned off on each, and address was set to 192.168.0.253 & 253. They were connected to Cisco 1G switch which is also connected to C6220.
Right now, with only the C6220 and nothing else connected, everything appears fine, although if I reboot a PC or laptop (both WiFi), I go through a period where the problem re-occurs, i.e. some websites available, unable to connect to C6220 for configuration, cannot ping DNS servers. Hour or two later, everything works fine.
