Dave_61
Nov 12, 2020Aspirant
PC slow to make connection through gateway after network address change
Model C6220 Firmware V1.02.11 Windows 10 home 19041.630 Chrome browser I wanted to add access points to my WiFi network. I reset my router to factory defaults as I was using an non-standard ad...
Nov 12, 2020Guru - Experienced User
What non standard address were you using on the LAN side?
How is the LAN side IP addressing configured now?
Did you power OFF ALL devices then back ON after resetting the modem and setting it up again?
What additional APs did you add?
gburns53
nm
