Ogiles54
Jul 09, 2016Aspirant
Pin for N300 wifi cable modem router
ModelC3000
- Jul 10, 2016
I have the N450 router but I suspect finding the PIN is the same for all of them.
Log into your router. The installation brocure tells you how to do this.
The left hand column gives the menu choices. Under Advanced select Wireless Settings.
The PIN will be under the in the row under the bold WPS settings label.
Ogiles54
Ogiles54@yahoo.com
