Jon110
Jun 10, 2016Aspirant
ping and tracert OK but no internet
I have a N450 CG3000Dv2 the cannot reach the internet, but ping and tracert requests are ok. The only incident was a power cycle or cut wednesday. there were not issues before that. The modem rout...
Jon110
With the DHCP server turned off and NAT turned off, I can access the internet through a web browser using a patch cable to port 1 of 4 on the device. PING and surfing are pretty quick. In this bridge mode, it seems the modem work but there are issues with the Router half of this N450 moden router.
Since Mediacom will not push software/firmware updates, it there a means for me to download and execute them myself? This assumes I need new firmware beyond NETGEAR N450 software version is V1.02.10
VE6CGX
Jun 10, 2016Master
Sounds like you have two routers involved. Like Modem >> router A >> another router.B. In this case router A should be put into bridge mode or router B should be in AP mode.
