MChang1
Feb 05, 2026Aspirant
Poor cable connection error message
I have Xfinity internet service. I have the Netgear CAX80 router/modem that I own. This was recommended by Xfinity. I read in the forums that the incoming speed is to fast for the router/modem?...
Feb 05, 2026Guru - Experienced User
If you can't post a photo of them, try copy/paste the details. Or at least write down what you have.
MChang1
It attaches the pdf file, but when I post it it erases it. I give. brian
- StephenBFeb 05, 2026Guru - Experienced User
If you have cloud storage (google drive, etc), you can try putting an image into the cloud storage, and then attach it using the "from image URL" option in the camera icon.
This won't work with the pdf, you'd have to paste it into an image.
- MChang1Feb 05, 2026Aspirant
it won't let me paste it, it's too much data. It let's me paste it, but then when I hit reply it won't reply, it just sits there.?? Brian
What file format?
How large is the file?
Can you convert it to text? There are some free tools
- https://www.online-convert.com/ocr/scan-to-text
