user124125
Dec 26, 2014Aspirant
Port Forward Not Working - C6300 AC1750
I have a server set at 192.168.0.100 for port 80 but the port forward is not working. I turned off the Media Server for the USB ReadyShare. If type my IP address it simply takes me to the router l...
jjrjr1
Mar 22, 2016Tutor
Hi
Thanks for your Suggestion..
I just made the change to the respomd to internet ping in the WAN Setup as suggested above..
IT DID NOT RESOLVE THE PROBLEM!!!
On Port 80 It gors to the Router Management Scree n instead of my running Apache Server
RDP simply does not respond (No forwarding on port 3389)
FTP also will not connect (No forwarding on port 21)
IS THERE A SOLUTION FOR THIS???
One would think NetGear would know how to make routers and not sell this rather expesive boat anchor....
What is the recomendation.. Trash this device and get a new one??
Thanks for any help
Chhers
John
DarrenM
Mar 23, 2016Sr. NETGEAR Moderator
Hello jjrjr1
What is your ISP and what firmware version is your C6300 running?
DarrenM
- jjrjr1Mar 23, 2016Tutor
Hi
Thanks for your reply.
My C6300 is running firmware v1.02.19
My ISP is Time Warrner.
Thanks
John
- DarrenMMar 24, 2016Sr. NETGEAR Moderator
Hello jjrjr1
That looks to be the issue it should be on V2.01.14 which is a firmware that fixed port forwarding they released this a month ago I would try to contact TWC ask for there Level 3 support and see if they can send some signals to your modem and do some reboots to try and get the firmware to your modem.
DarrenM
- neoklisJun 15, 2016Aspirant
I'm also having problems with my C7000 Nighthawk router. I can't get port forwarding to work on any port. I can only "see" my cam when I set it's IP on a DMZ. Spent hours and hours with Netgear support. Re-ordered the same device from Amazon. Messed with all of it's settings and still the same problem. I think I'm going to send it back and go back to Linksys.
I've done port forwarding before on Linksys and Ubee routers with no issue. Definitely there's some sort of glitch in the firmware. Horrible device testing from Netgear.
ISP: Time Warner Cable
