user124125
Dec 26, 2014Aspirant
Port Forward Not Working - C6300 AC1750
I have a server set at 192.168.0.100 for port 80 but the port forward is not working. I turned off the Media Server for the USB ReadyShare. If type my IP address it simply takes me to the router l...
Babylon5
Dec 27, 2014NETGEAR Employee Retired
In your first screengrab I see that ‘Port Forwarding’ is set to ‘Never’, it should be ‘Per Schedule’ or ‘Always’. Also many Netgear home grade routers don’t support Loopback, which is what would be needed to test port forwarding from within your LAN, so you might want to make sure that all your tests are external, say from a web based port checker or a smartphone/tablet using 3G/4G.
