user124125
Dec 26, 2014Aspirant
Port Forward Not Working - C6300 AC1750
I have a server set at 192.168.0.100 for port 80 but the port forward is not working. I turned off the Media Server for the USB ReadyShare. If type my IP address it simply takes me to the router l...
DHabibi
Feb 21, 2015Novice
Have been messing with this for a few hours and talking with tech support and they wanted me to reset the modem and setup again, etc. etc. I am a software engineer and have setup quite a few modems, the port forwarding on Netgear AC1750 simply does not work, DMZ also does not work. You keep getting the log on screen even when you do not have the remote administration active. Have switched back to old Netgear cable modem, will buy a different modem, need to upgrade for better speed. If anybody has fixed this problem somehow love to know. Was hoping could do a firmware upgrade but I guess that is done via the cable company and there does not seem to be any. We should be able to upgrade the software in our own modems!
