user124125
Dec 26, 2014Aspirant
Port Forward Not Working - C6300 AC1750
I have a server set at 192.168.0.100 for port 80 but the port forward is not working. I turned off the Media Server for the USB ReadyShare. If type my IP address it simply takes me to the router l...
Babylon5
Feb 22, 2015NETGEAR Employee Retired
DHabibi wrote: You keep getting the log on screen even when you do not have the remote administration active.
This is a typical response when testing port forwarding using the Public IP from within the LAN, is that what you did? I expect that the router does not support Loopback.
