user124125
Dec 26, 2014Aspirant
Port Forward Not Working - C6300 AC1750
I have a server set at 192.168.0.100 for port 80 but the port forward is not working. I turned off the Media Server for the USB ReadyShare. If type my IP address it simply takes me to the router l...
DHabibi
Feb 23, 2015Novice
I am waiting for a level 2 support from Netgear. Everything I have works fine with an old Netgear (2.0 modem). Bought the 1750 and can not get it work in any which way. I am wondering if the USB sharing is getting in the way and when I go to disable it it complaints about ports being assigned to other stuff. Even with every other setting removed still can not disable the USB sharing, simply does not want to go away. Was about to buy the N600 modem, have not heard about too many problems with that one but I did see some things so now wondering. Again I have an old Netgear working great, expect slow. Changing nothing on my network, setting up the new one to work just like before and it is refusing. Again if anybody gets and answer or solution let everybody know.
jmknapp80
Aug 26, 2015Aspirant
Has anyone managed to get port forwarding working? I simply can not. It just doesn't work. How can this be??
- jmknapp80Aug 28, 2015Aspirant
Can someone from NetGear add any insight about this issue? This is so frustrating.
- DarrenMSep 02, 2015Sr. NETGEAR Moderator
Hello jmkapp80
When you say that port fowarding isnt working for you do you mean you set up port fowarding and what your trying to foward isnt working or is it not even allowing you to foward ports at all?
DarrenM
- jmknapp80Sep 10, 2015Aspirant
Thanks for the reply Darren.
I set up port forwarding according to the instructions. When I go to http://www.canyouseeme.org/, the ports that I opened are showing as not open.
As you may have read, I am not the only one having this issue, and no one has responded to this thread at all that they successfully have port forwarding working.
