user124125
Dec 26, 2014Aspirant
Port Forward Not Working - C6300 AC1750
I have a server set at 192.168.0.100 for port 80 but the port forward is not working. I turned off the Media Server for the USB ReadyShare. If type my IP address it simply takes me to the router l...
jmknapp80
Aug 26, 2015Aspirant
Has anyone managed to get port forwarding working? I simply can not. It just doesn't work. How can this be??
jmknapp80
Aug 28, 2015Aspirant
Can someone from NetGear add any insight about this issue? This is so frustrating.
- DarrenMSep 02, 2015Sr. NETGEAR Moderator
Hello jmkapp80
When you say that port fowarding isnt working for you do you mean you set up port fowarding and what your trying to foward isnt working or is it not even allowing you to foward ports at all?
DarrenM
- jmknapp80Sep 10, 2015Aspirant
Thanks for the reply Darren.
I set up port forwarding according to the instructions. When I go to http://www.canyouseeme.org/, the ports that I opened are showing as not open.
As you may have read, I am not the only one having this issue, and no one has responded to this thread at all that they successfully have port forwarding working.
- DarrenMSep 11, 2015Sr. NETGEAR Moderator
Ok I am currently having this issue being looked into since I do see that many people are experiencing the same thing I will let you know what I can find out about the issue.
DarrenM
