user124125
Dec 26, 2014Aspirant
Port Forward Not Working - C6300 AC1750
I have a server set at 192.168.0.100 for port 80 but the port forward is not working. I turned off the Media Server for the USB ReadyShare. If type my IP address it simply takes me to the router l...
Rockne
Oct 11, 2015Aspirant
I was having the same problem and I just checked the box next to "Disable port scan and DOS protection" in the "WAN Setup" tab. I tested using Open Port Check Tool at canyouseeme.org and it is now seeing my forwarded ports. I am a novice so I would apprciate to know if this is going to open me up for other more serious problems. Thanks.
- jd69627Oct 13, 2015Aspirant
Did you ever get an answer on the WAN setup option?
