Cdtek101
May 26, 2016Aspirant
Port forward rules limited to 9 ports
I have a Netgear CG4500BD Modem/Router I have 13 cams. (just got last 4) I cant add another port forward rule (limited to 9) so I cant add additional cams in port forwarding. I can't make a r...
Cdtek101
Update :::::::::::::::::::
If I don't need to assign a port forward for each camera.
But what port do I input in camera when it says port ?
In blue iris I took out the port #,
i can see the camera inside and outside network...
but the camera ip in blue iris defaults to port 80 in configuration ?
I set another cam the same way defaulting to port 80, it works also.
So - How many cameras can be on one port number ???
Cdtek101
May 27, 2016Aspirant
Ahhhh Ha...figured it out....don't even need port forward since I have no need to log into each camera from outside my LAN....I can see all cams
outside through Blue Iris web server...
