ka9mgd's avatar
ka9mgd
Follower
Sep 18, 2016
port forwarding for echolink
How do I port forward this modem for  UDP to ports 5198 and 5199, and outbound TCP to port 5200 for echolink?
  • TheEther's avatar
    Sep 18, 2016
    The CM400 is a pure modem.  It doesn't have a router.  Therefore, port forwarding is not necessary.
    If you have a router plugged into the modem, then you would need to set up port forwarding on that router.
