Xerterion
Oct 20, 2017Aspirant
Port Forwarding Issues
Hello Netgear Community, My ISP is Cox Communications i have a Netgear C6300BD Modem and ive been trying to setup port forwarding on it but when i do an then go to the website canyouseeme.org it ...
antinode
Oct 20, 2017Guru
> [...] ive been trying to setup port forwarding on it but when i do an
> then go to the website canyouseeme.org it keep saying the ports i want
> are still closed even though that i port forward them correctly.
It's interesting that you believe that you configured port forwarding
"correctly", but it might be more informative to show the actual
port-forwarding rules. Copy+paste is your friend.
Are you running any server program on the target system which is
listening at a forwarded port? "the website canyouseeme.org" is testing
at the router's public address. Have you tried any (local) testing of
the target system at its LAN address? Both should work, and only one
depends on the router's port-forwarding anything.
In my experience, people who talk about ports being closed often
don't understand the problem. A port looks "closed" when there's no
server program listening at that port. All the port forwarding in the
world won't help you if, at the end of the line, no one is listening at
that port number.
> [...] It is set to DCHP but unfortunatly cox disabled my option to set
> my ip address to static so i cannot change it on the modem itself.
"It"? Are you talking about the router's WAN/Internet interface?
The ISP controls that (public) address. Why do you think that you want
to change it?
Why, exactly, are you doing any of this? Is there some actual
problem which you are trying to solve?
- XerterionOct 20, 2017Aspirant
Here are the screenshots of my router configuration
thats the port im trying to open but always keeps saying connection timmed out for the port
- antinodeOct 20, 2017Guru
> [... port 53 -> port 53 ...]
I can believe that. Port 53 is used for a DNS server. I'd be a
little amazed if your XboxOne were running a DNS server, hence it's not
amazing that you're getting no response from it at port 53.
Still wondering.
