Colorman's avatar
Colorman
Port Forwarding not working
First of all, information. Router model: CG3700EMR. Firmware Version: V2.01.03   The model isn't on this website for some reason, but I found somewhere that the CG3700 is very similar to the CG32...
  • antinode's avatar
    antinode
    Sep 29, 2017
       You've published your public IP address, and obscured your (harmless)
    private address.  You're keeping the wrong address secret, which helps
    no one.
    > [...] multiple ports forwards (one for TCP and one for UDP) [...]
       That was a waste of effort.  One rule can do both.
    > The port stays closed no matter what I do [...]
       Are you running a server at 192.168.blur.blur which is listening on
    port 25565?  What is the server at 192.168.blur.blur?
       In my experience, people who talk about opening ports often don't
    understand the problem.  For a port to appear to be "open", there must
    be a program on the target system which is listening at that port.  If
    you're not running such a program, then all the port forwarding in the
    world won't help.
