Colorman
Sep 29, 2017Aspirant
Port Forwarding not working
First of all, information. Router model: CG3700EMR. Firmware Version: V2.01.03 The model isn't on this website for some reason, but I found somewhere that the CG3700 is very similar to the CG32...
- Sep 29, 2017
You've published your public IP address, and obscured your (harmless)
private address. You're keeping the wrong address secret, which helps
no one.
> [...] multiple ports forwards (one for TCP and one for UDP) [...]
That was a waste of effort. One rule can do both.
> The port stays closed no matter what I do [...]
Are you running a server at 192.168.blur.blur which is listening on
port 25565? What is the server at 192.168.blur.blur?
In my experience, people who talk about opening ports often don't
understand the problem. For a port to appear to be "open", there must
be a program on the target system which is listening at that port. If
you're not running such a program, then all the port forwarding in the
world won't help.
antinode
Sep 29, 2017Guru
Colorman
Yeah, I want to delete that one because I figured out that that wasn't the problem...
- antinodeSep 29, 2017Guru
no one.
world won't help.- ColormanSep 29, 2017Aspirant
Thanks for the blur info. I'm a newbie when it comes to that kinda stuff. I'm running a server on my internal pc address 192.168.0.22. I have actually never tried running a program while testing the port.
Just did so and it actually worked for once! Thank you very much! I've tried to get this to work for 3 days and the answer was so simple.... But thank you again!
