PDIGS44
Jan 26, 2017Aspirant
Power Adapter Replacement???
Hi. I must say, I'm very disappointed with Netgear's support when it comes to replacement information. I have a new CM600 Modem that I can't set up because my stepdaughter accidentally threw out the...
DarrenM
Jan 30, 2017Sr. NETGEAR Moderator
Hello PDIGS44
Here is a picture of the specs of the power bricks to help you find the correct one you need.
DarrenM
- supersenderJun 27, 2017Aspirant
I Plan to buy a Netgear CM 700 , But it will be used in India, Can anyone please tell me if the power adapter can be used in 240V l , 50 Hz power lines . Most of the Netgear products i have bought have power adapter which specify 110/60 hz to 240v/50 Hz , I cannot find any mention of this on the netgear website in the technical specs
- DarrenMJun 29, 2017Sr. NETGEAR Moderator
Hello Supersender
I have a picture of the adapter that comes with this modem and it is the same as your other netgear adapters.
DarrenM
