nealct56's avatar
nealct56
Power yet no connection
Nighthawk AC1900 WiFi Cable Modem Router
Cable is connected; Power Cord connected
Solid white constant light on top side reset button, and Tel 1 LED, Tel 2 LED, and Battery LED. All other LED lights are not on.
WiFi Not Connected when checking Settings on iPhone XR
  • plemans's avatar
    What AC1900 do you have (hint ac1900 is the speed, not the model)?
    If its a modem/router combo device, have you tried unplugging the coax, then doing a reset on it? Push and hold reset for 7-15 seconds while its powerd on (with coax disconnected)?
    • nealct56's avatar
      nealct56
      Thanks! It is a model C7100V
      The top constant on button is the PUSH ‘N’ CONNECT—Easy push button WiFi connections (WPS)
      I held that button for 10 secs with power plugged in and cable disconnected. No change. Try small recessed reset next?
