Majji
Dec 12, 2017Aspirant
PPPOE OPTION not displaying to setup
PPPOE OPTION not displaying to setup. Please help
antinode
Dec 12, 2017Guru
Visit http://www.netgear.com/support , put in your model number, and
look for Documentation. Get the User Manual. To me, your picture looks
like what the User Manual shows.
The C3000 is is a cable-tv modem+router. Why do you expect to see
PPPoE anywhere? Is there some actual problem which you are trying to
solve?
Majji
I took connection from internet provider in india. Requested to provide the user and password in PPPOE settings. But it's displaying different options when I login to the netgear genie -advanced setting-setup-internet setup.
- antinodeDec 12, 2017Guru
Did that (unspecified) ISP supply the modem, or tell you which modem
to use?
To me, your C3000 seems to be doing what a C3000 does, which does not
involve PPPoE. Perhaps you should ask your ISP. I have DSL service,
which can involve PPPoE, but a C3000 is the wrong type modem for that.
