daw59
Jun 15, 2017Aspirant
Problem connecting to C7000
Is anybody experiencing connection problems with their C7000? I can't connect via the web interface or Genie after it's been running for a while. If I hard reset it, then I can login just fine ...
DarrenM
Jun 21, 2017Sr. NETGEAR Moderator
Hello daw59
Have you you tried to use 192.168.0.1 to get to the web interface?
DarrenM
daw59
Jun 21, 2017Aspirant
Yes, and I can connect right after resetting the modem, but after it's been running a while, then I can't connect with either web or Genie.
- DarrenMJun 22, 2017Sr. NETGEAR Moderator
Hello daw59
When this happens are you able to do a IP config and see if the default gateway address has changed.
https://www.lifewire.com/how-to-find-your-default-gateway-ip-address-2626072
DarrenM
- kbkevin11Jul 14, 2017Aspirant
I have the same problem. Is there any fix to this. So I can reset the c7000 modem and then I will be albe to login to the c7000 is what I am hearing is that corrrect? Is there any idea why this happens and is there a permit fix.
