drjtech
Oct 30, 2025Guide
Problem with port forwarding not working on my CAX80 connected to Xfinity.
I was having the same problem with port forwarding not working on my CAX80 connected to Xfinity. After double and triple checking for errors on my part I checked the web for a solution and found your...
Oct 30, 2025Guru - Experienced User
How is PF configured on the gateway?
Is uPnP disabled on the gateway before setting any up any PF configurations.
After v5 FW is applied, have you performed a factory reset and setup from scratch to check this?
I'll pass this along to NG along with any and all troubleshooting details you have.
