craigwf's avatar
craigwf
Tutor
Sep 21, 2026
Problems with new AX2700
The first issue is universal with all Netgear products.  Netgear's MAC address uses two slightly different size zeroes which make you think the larger, rounder one must be an "O."  I spent an uncomfortable hour on the phone with Xfinity trying to get my new AF2700 activated with them because we had the wrong MAC address,  Please use the european way of writing a slashed zero to avoid this headache (accompanied by swear words) of distinguishing the zero fram an "O".
Secondly, the AF2700 (CAx30) established a new network in my Win 10 pc that worked fine for all purposes except it would not allow me to play my online golf game using direct connect even though I had properly set up the required ports to be forwarded.  The second day of expert assistance with this issue discovered the router had unknowingly created a public network which my game does not allow for direct connect play.  Is that what is supposed to be the default network when you install a Netgear cable modem router these days?  Of course not!  For any number of reasons, mostly involving privacy and security, the default should be a private network.  Make it so.
  • Thanks, Stephen.  The two different sized zeros are on the label attached to the router.  Knowing hexidecimal only uses A thru F is good to know.  Maybe the Quick Start document should mention that.
    • FURRYe38's avatar
      Can you post a screen shot of just the MAC address printed on the CAX sticker?
      • craigwf's avatar
        craigwf
        Tutor
        No. I am satisfied with the answer that it can't be an O in MAC addresses.  The first 0 that comes after an E is both slightly taller and wider than the subsequent 0 which follows numbers.
  • StephenB's avatar
    I haven't noticed that myself.  Where were you seeing this?  On a label?  In an app?  Or possibly the web management UI?
    In any event, MAC addresses are always shown in hexidecimal (by everyone, not just Netgear), so the only letters are A-F.  Xfinity support should have known this.
    The private/public classification of networks is done by Windows, not the router.  Windows always classifies a new network as public, as that is safest from a security perspective.  The router has no control over that classification.
