Kevin932
Aug 17, 2017Follower
Prosafe wireless Password
I know the password to connect my phone to the wireless on this router, but can't seem to find where to change it. I really don't want to reset because I didn't set it up and would have to call my IT support person. Where do I do this?
Your help is appreciated.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Kevin932
You would open a web browser and plug 192.168.0.1 or 192.168.1.1 in your URL bar then it will ask you to log in you want to use admin/password then go to the wireless settings and you should be able to change the wireless password.
DarrenM
