GhillieK9
Jan 13, 2019Apprentice
Put C7000 in bridge mode or buy a CM1000?
Hello,
I have Comcast and have the Nighthawk C7000. It has worked great! I wanted to see what I am missiong out on as far as a great router. I wanted to buy either XR500 gaming router...or the ...
Nodism1125
Jan 14, 2019NETGEAR Expert
C7000 is a DOCSIS 3.0 while CM1000 and CM1150V is a DOCSIS 3.1.
There is a difference between 3.0 and 3.1 in performance.
https://kb.netgear.com/000060401/
Note: CM1100 and RAX80 recommended combination.
I would recommend to put the C7000 in bridge mode since you are planning to buy router as upgrade for now.
Select ADVANCED > Administration > Router Mode
Select the No radio button.
- GhillieK9Jan 14, 2019ApprenticeThank you!
I ended up buying a CM1100 and the XR700. I'll just sell my C7000 on eBay.
