marxiouis's avatar
marxiouis
QoS tab missing on N450
I am trying to take a speed control over my network device, but when I follow the instruction and get to the QoS setting tab, it's just not there. My firmware version is
V3.01.06 and my model is N450 WIFI router. Kindly help resolve the issue...
  • michaelkenward's avatar
    michaelkenward
    Are you sure that, as described in your message, this is a WNR2500? (N450 is a wifi standard not a model number.)
    The support pages for the WNR2500 have never heard of firmware version V3.01.06.
    >>> WNR2500 | Product | Support | NETGEAR <<<
    You'll find the model number on a label like this:
    model number
    • marxiouis's avatar
      marxiouis
      Hi, sorry about the confusion, if I were to look at the model number , it wrote CG3000Dv2. Please help me with QoS issue, TIA
      • DarrenM's avatar
        DarrenM
        Sr. NETGEAR Moderator
        Hello Marxiousis
        The cable modem routers do not have advanced QOS features.
        DarrenM
