iopredman
Feb 06, 2020Initiate
Quality of Service settings do not save
Model: WNDR4500v2
Fireware: 1.0.0.72_1.0.45
OS: Windows 10 Pro Version 1909 Build 18363.592
Steps to repeat:
1. Log in to router.
2. Navigate to QoS setup via Advanced -> Setup -> QoS setup
3. Set uplink value at 9 Mbps
4. Check mark the box "Enable Upstream QoS"
5. Hit "Apply"
6. After the loading bar is finished, check box is
unchecked and uplink value is blank
Note: I already have a QoS rule saved.
This rule can be reached by clicking QoS rule.
It does not reset unlike the checkbox.
Note: Router and modem have been reset.
Note: Portforwarding and Dyanamic DNS are enabled and being actively used.
Note: Computer is a wired connection
Any ideas or help would be appreciated!
Please post about this here for your model router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-generalGood Luck.
