brandoncampbell
Nov 05, 2015Guide
Question about DDNS and freedns.org
Looking to see if I purchased the NETGEAR Nighthawk AC1900 Wi-Fi DOCSIS 3.0 Cable Modem Router (C7000-100NAS) if it supported adding DDNS addresses. Specifly I will need to add freedns.afraid.org so ...
brandoncampbell
Nov 05, 2015Guide
I'm not seeing any. I don't have the device - I was planning on buying the device if I can add a custom DDNS entry or if it already supports freedns.afraid.org - Do you happen to know?
vkdelta
Nov 05, 2015NETGEAR Employee Retired
Sorry, afraid.org is not there.
I see there NETGEAR-NOIP, NOIP,dyndns.org, and dtdns.com options in there..
can you use above options?
- brandoncampbellNov 05, 2015Guide
unfortunaly not for what i am using it for. I have a hostname already that I registered this was the best free option. - is there an ability to add?
