cuse165
Jul 27, 2016Aspirant
Question about two products Netgear C6250 Netgear C6300
My question is about two products the Netgear C6250 and the Netgear C6300. Is there any major difference between the two and what one would be better performance wise? Thanks
- Jul 29, 2016Okay thank you very much!
DarrenM
Jul 29, 2016Sr. NETGEAR Moderator
Hello cuse165
The C6300 has a slightly better performance
- AC1750 WiFi - 450+1300 Mbps speed
The C6250 is
- AC1600 WiFi—300+1300 Mbps†
So it just down to what your budget is.
DarrenM
