Jetguy
Feb 27, 2019Aspirant
Question Regarding Netgear AC1900 C7000 Modem/Router
 Hello All,
 I plan on switching from Uverse to Xfinity.  The self-purchase modem I have in mind is the C7000 modem/router.  I have one brief question about this product for which I have not directly...
- Feb 27, 2019
Thank you Antinode for taking your time to answer my query with your valuable information. I was certain it would work but I just wanted to be sure of it. I ordered the C7000 and its on its way.
antinode
Feb 27, 2019Guru
> [...] Of course the switch is plugged into the back of the modem
> ethernet port. [...]
   Of course, one port of the switch is connected to one of the LAN
Ethernet ports of the modem+router.  (The switch itself won't fit into
one of those little holes.  And, I'd bet that there's more than one
"modem[+router] ethernet port".)
> [...] Will I be able to plug the GS108 switch in the back of the C7000
> for connectivity of my 6 devices plugged into the switch? [...]
Sure. Exactly as with your old (or practically any other) router.
> [...] If so does it matter which of the C7000 ports the GS108 should
> be plugged into? [...]
All the C7000 LAN Ethernet ports should be equivalent.
> [...] the C7000 only has 4 Ethernet ports its not enough for me. [...]
   That's why network switches exist.
