Jaughn_Dough's avatar
Jaughn_Dough
R6200v2 Unable to open ports
I recently moved into a new apartment and have been trying to set up my a port on my network to run a server, but it is not opening.
I have already allowed the port through my firewall and even turned my firewall off to test the port, but that isn't making a difference.
I have also set up an address reservation to the PC I am sending the server to and the same IP matches the one when I create the service in the port triggering menu. The port I am using is 25565. I have tried others to see if I can get any to open, but have had no luck with those either.
My firmware version is V1.0.3.12_10.1.11.
I tried to set up a port in my previous home, but figured the ISP blocked my port since it was shared housing, now I am not so sure and think there may be another problem.
I have successfully opened ports on this computer in the past, so I am not sure why I have been having these issues for the last 2 years.
  • antinode's avatar
    antinode
    Jul 06, 2019
    > Could you explain how I find the address? [...]
       Which "the address"?  Every network interface has one (and your
    router has two, which you seem to have found).
    > My Internet IP address is being obtained dynamically from the ISP and
    > my Internet Port IP address is 192.168.1.64. The Router Information IP
    > address is 10.0.0.1.
       And there it is.  "192.168.1.64" is a private address, assigned to
    your NAT router by some other NAT router, hence "double NAT".  Any
    effective port forwarding would need to be done on the other router
    (which, presumably, but not certainly) has a public address on its far
    side.
       The R6200v2 would normally use "192.168.1.*" on its LAN side, but it
    detected that subnet on its WAN/Internet side, and thus switched to
    using its alternate LAN subnet, "10.0.0.*" to avoid the conflict.
    > Not sure if any of that is helpful or not.
       It's everything which is needed to reveal that you're approximately
    doomed.
       The only solutions I know are: 1) to ask your ISP for a real public
    address (which I'd guess might not be possible with the current
    apartment service scheme), or 2) to use a tunneling service like the one
    mentioned in another recent thread (near the end):
          https://community.netgear.com/t5/x/x/m-p/1748431
  • > I recently moved into a new apartment [...]
       From what/whom do you get your Internet connection?
       What's the IP address of the WAN/Internet interface on your R6200v2?
    Is it a public address?
       The usual problems with this stuff are:
       1. Wrong external IP address (different from the port-forwarding
    router's WAN/Internet IP address).  (An intermediate NAT router, for
    example, could cause this.  Or an ISP using carrier-grade NAT to
    conserve IPv4 addresses.)
       2. Bad port-forwarding rule (wrong port(s), wrong target address --
    including a wandering target).
       3. Server not listening on the port-forwarding target system.
       4. External influences: ISP blocking, other firewalls, ...
       You seem to be dealing with 2-4, but if your apartment building
    provides your connection, then my money would be on "1".
    • Jaughn_Dough's avatar
      Jaughn_Dough
      I receive my connection from AT&T's fibre service. They partner with the complex I am in, but are considered seperate, both in costs and service provided.
      Could you explain how I find the address? The WAN setup has the default DMZ Server box checked which is the same as my IP as my local PC. My Internet IP address is being obtained dynamically from the ISP and my Internet Port IP address is 192.168.1.64. The Router Information IP address is 10.0.0.1.
      The address from my PC is 10.0.0.2.
      • antinode's avatar
        antinode
        Guru
        side.
        doomed.
