JarthMader
Dec 09, 2018Aspirant
Random disconnects with CM400 modem
I replaced a 10 year old, burnt out Motorola modem (no connection issues before it died) with a Netgear CM400 back from Best Buy in August 2018. Since then, I've been getting random disconnects. Usua...
JarthMader
Dec 12, 2018Aspirant
I did some more research over the past couple days and have made some changes. So, I found the other modem diagnostic page that shows power levels, correctable and uncorrectable errors. With my original setup (50 ft coax cable from the wall to the modem) the power levels on the downstream channels were around -12 to -15 dBmV. After switching my setup around to have the modem and router close to the wall outlet (1.5 ft coax cable, 50 ft ethernet cable to my PC) my downstream power levels are now -3 to -6 dBmV. I haven't had any disconnects for the past two days, but my correcable and uncorrectable errors seem really high:
| Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
I did a little math (last modem reset was about 42 hours ago), and that comes out to an average of 79k correcables per hour and 19k uncorrectables per hour over all 8 channels. If I'm understanding this all correctly, the uncorrectable errors are bringing down my effective bandwidth. Could this be due to bad wiring in the apartment? Previously on the phone Cox claimed the lines they had control of showed great diagnostic results.
